Related Item XTD Order By?
- Posted by mkpdroid (12) Offline
Hi TP Support,
Thank you for your previous support.
I have a question about Related Item XTD Order by :
in your module tooltip there are some option like this :
but in my module Order by Setting displayed like this screen shot :
prntscr.com/2irjql
And then, when I set the module order by to "Recently Created First", but the module not display recently created first of article.
Please see below screen shot :
prntscr.com/2irly2
In my perception, when i choose 'Recently Created First" the module will be display latest/newer articles from the same tag/meta keyword, but in my website it doesn't.
my live website :
diandidaktika.sch.id/kegiatan-sma/205-ti...a-1-tingkat-nasional
12 years 9 months ago #1
by mkpdroid
Recently Added First
Recently Modify First
Recently Published First
Recently Touched First
prntscr.com/2irjql
prntscr.com/2irly2
my live website :
HI,
Can you tell me what based setting did you use? Is it meta keyword based or tag based?
Can you check whether each setting return the same behaviour?
12 years 9 months ago #2
I used tag for my website.
this is the example :
Category A:
There are 10 Article with the same tag
Today there are 2 article update.
When people pick 1 article from today update. The module not show latest article in the same tag, but the module show another old article in the same tag.
I give you my website details.
12 years 9 months ago #3
by mkpdroid
Category A:
Hi mkpdroid, i'm not familiar with your website content structure and I can't replicate the problem at my end. As I mentioned before can you try to use the meta keyword option to check whether the meta based option returns the same behaviour with tag based.
12 years 9 months ago #4
