Carousel Banner vanished
Hi!
I've managed to set the carousel banner one time, it has worked fine until today, when I installed a new module: Simple Spotlight Slideshow to my site (teszt.vsz.hu/) The Carousel Banner module should be shown up on the bottom of the site under the heading "Partnerek". But it has vanished. :(
If I check the css with firebug, #mycarousel-139 is set to display: none, if I change this, my pictures shown up, without doing anything. Maybe, installing the new module overwrited the jquery file?
Please help me!
Thank You!
Gabor
12 years 9 months ago #1 by Gabriel Flames
Hi, From what I see, your website loads multiple jQuey. Please try to make jQuery loaded one time only
See d.pr/i/BvA1
12 years 9 months ago #2 by TemplatePlazza
Where and how can I do that?
Thank you!
12 years 9 months ago #3 by Gabriel Flames
For Carousel Banner, you can disable jQuery load from the module backend. For other extensions you should check it on their backend too whether they have option to disable jQuery too.
You might want to try this extension too :
extensions.joomla.org/extensions/core-en...jquery-scripts/18327
12 years 9 months ago #4 by TemplatePlazza
Thank You very much!
Now it works fine! :)
12 years 9 months ago #5 by Gabriel Flames
Great, glad it helps;)
12 years 9 months ago #6 by TemplatePlazza
