Pop-Login, invalid cookie, on PCs
Hi there,
It appears that when users try to login to the site [which has conservative caching and system-cache turned on ], they are getting Invalid Tokens often on PCs [Firefox etc] [seems to be working fine from Safari/Chrome/ etc on Macs...
Besides turning off caching which is obviously not good for performance reasons, any other way to make sure PCs have a working login from the module?
Thanks!
Cheers,
E.
11 years 9 months ago #1 by exlemor
  • Posted by TemplatePlazza (5367) Offline
Hi, can you check this issue with default joomla login module and see whether the problem persist or not?
Because pop login is actually = default joomla login + jquery + css styling
11 years 9 months ago #2 by TemplatePlazza
