JCE - XTypo and Fonticons can not be saved
I installed Xtypo Buttons and fonticons but can not save fonticons with a JCE-editor.
Everything else is okay: I can choose and include an icon, it is visable in the editor but when I try to "save" the article the icon is not there any more.
I don't know how I can fix this.
12 years 9 months ago #1 by Sab
Hi, Is it possible for you to share temporary access to your website so I can test it by myself?
If yes, you can share it by using Your Site Details tab below. Only support team will be able to see it
12 years 9 months ago #2 by TemplatePlazza
Okay, even that I am a bit scared of giving my details to a stranger.
Everything on my site as well as Joomla administration is in German.
Today I tried again and again including a fonticon in an article. I found out that when I type a space behind the fonticon and delete the space again and .... and .... it is not easy to found out when it happend .... but after a while I can save the article and the fonticon is still there.
But this can not be the solution!
12 years 9 months ago #3 by Sab
Hi sabho,
I found you have typed the "Extended Elements" values incorrectly.
You typed :
span[class]
i[class|style]
where it should be like this (separated by comma)
span[class],i[class|style]
I've changed it, and it looks like working good now. Please check
12 years 9 months ago #4 by TemplatePlazza
Thank you very, very much - This is great support.
12 years 9 months ago #5 by Sab
Ok nice, thank you for your confirmation ;)
12 years 9 months ago #6 by TemplatePlazza
