I cant get the responsive slider banner to work with joomla 3.2
It says the modual is there in the back end but the responsive slider banner is missing in the front end.
Please look in your site details.
12 years 8 months ago #1 by matthew
Hi, can you tell me in what posistion you have published the module?
12 years 8 months ago #2 by TemplatePlazza
cell-6a which is about in the middle and cell-9a which is at the verry bottom.
12 years 8 months ago #3 by matthew
H, I have take alook at your website. It doesn't displayed because the joomla doesn't recognize the position cell-6a and cell-9a.
It looks like you have modified the template codebase to weork with joomla 3.0 but it doesn't fully support the new system
12 years 8 months ago #4 by TemplatePlazza
Ok so the responsive slider banner doesn't fully support the new system joomla 3.20?
12 years 8 months ago #5 by matthew
It.s not about the module. It's about the template you use. Deal plazza doesn't support Joomla 3.x but it looks like you have modified it to work with joomla 3 but the modification looks doesn't works well.
Please go to the module backend, you'll found that you can't choose the cell-6a position from the dropdown d.pr/i/VxC0
12 years 8 months ago #6 by TemplatePlazza
