Doesn't have jQuery lib installed
I'm having problem after installing quick start package. I got this on top of 'login or sign up' button
Your template does't have jQuery lib installed. Please enable jQuery from the module backend parameters to make it work
12 years 8 months ago #1 by NN
Hi, Can you tell me what extension you're talking about? Additionally, can you share your website URL so I can take a look?
12 years 8 months ago #2 by TemplatePlazza
Hi, thanks for replying. I already fix it. Just curious, can we set the deal showing in grid view instead of list in one column?
12 years 8 months ago #3 by NN
Ah ok. Thanks for the confirmation.
I don't really get it, can you elaborate more?
12 years 8 months ago #4 by TemplatePlazza
The item right now is listing 1 item per row. Was planning to make it like 3/4 item per row. Also, my countdown timer seems to have a problem. Is there anything i have to set? Btw, i'm using quickstart package to test this
12 years 8 months ago #5 by NN
I feel like i just wasted money on this. Documentation is not complete..
- Private Support Forum Access
This forum is not even a private one :\
12 years 8 months ago #6 by NN
