need help with Responsive Banner Slider
Hi Iam the newbie here and to whole joomla thing also i have installed the xamp on my system and downloaded the Joomla 3.2, and using its default template which is protostar - Default, after installing the Responsive Banner Slider extension , as shown in PDF file i have created 3 banners , Components > Banner > Banners , the publish the Responsive Banner Slider through Model Manager , In this template i set Banner position under "banner"
but nothing is working its not showing any banner.
any advise
12 years 8 months ago #1 by ken
Hi kenn07 Can you share your website URL so I can take a look?
12 years 8 months ago #2 by TemplatePlazza
Its On My laptop as i mentioned I am using through xamp. no idea how can i share with you
12 years 8 months ago #3 by ken
Hmm, it's hard to track the problem without seeing directly to the website. Did you follow the documentation file already?
12 years 8 months ago #4 by TemplatePlazza
Yes i Did Follow the document , Do u like to remotely connect to my my laptop ....
12 years 8 months ago #5 by ken
Hi kenn07, We're sorry we can't do that. The easier way is to upload your website temporarily to live server so then we can't check it from here.
12 years 8 months ago #6 by TemplatePlazza
