hidden-phone suffix does not implement
Joomla 3.2.2, Gantry 4.1.20 using Twitter Bootstrap2. Pagepeel works fine except that i'd like to hide it on phones. Normally the bootstrap CSS for that is (space)hidden-phone
Putting that into the module class field in Advanced tab works on other modules... but not this one. There must be another place to enter that into the module code. Where? Thanks... Happy to pay for support on this, it's a commercial project.
12 years 8 months ago #1 by David McCreary
Hi, If you use gantry or other template framework that using bootstrap, then adding .hidden-iphone in the module suffix should hide your module in mobile devices
12 years 8 months ago #2 by TemplatePlazza
