elements are not aligned
- Posted by accounts vari (13) Offline
Hi, sorry for delay in responding. I have netered your website and it looks like the module works like it should. Can you tell me what you're expecting to get?
12 years 8 months ago #2
hi,
look at this demo
lafoodsitter.lucaddeu.it/index.php/en/kitchen-stories-eng
there is white space in the vertical
thanks
12 years 8 months ago #3
by accounts vari
look at this demo
thanks
Hi, Can you switch your template to the default one to check whether this is a template problem or something else?
12 years 8 months ago #4
