Page Peeler 2.5.. how to publish...
I couldn't find any information.. But where should I publish it (position) to make it work?
13 years 11 months ago #1 by Jeremy Otten
Hello Jeremy
You can publish it in any module position your template has.
13 years 11 months ago #2 by erwinschro
Hi there,
I am trying to publish the module. As soon as I publish it, the site becomes unaccessible. White background.
What would be the reason? Thanks.
13 years 10 months ago #3 by gokhan
Solved :)
com_banner was unistalled. I was not using it before. I copied the com_banner file to the appropiate folder and problem fixed.
13 years 10 months ago #4 by gokhan
Yes gokhan2,
This module need com_banner
thanks for your confirmation
13 years 10 months ago #5 by ronysyz
