Banners not rotating
Just installed Responsive Banner Slider Module, but banners are not rotating.
I also have TCVN Banner Slider Module installed - will there be a conflict?
12 years 7 months ago #1 by Philip Mayday
Hi can you try to enable jquery load from the banner backend?
12 years 7 months ago #2 by TemplatePlazza
Hello, I have the same problem; banners are not rotating (anymore). I had installed the responsive banner slider over a year ago and everything worked fine. Suddenly the banners stopped rotating. First I thought it was a browser issue, but Safari, Chrome and IE all have the same behaviour. I'm not aware of anything changing in the backend. I have re-ordered the responsive banner slider today and re-installed, thinking it might be updated but the problem persist. I don't realy get wat the comment about jquery means (where can I load jquery?). I installed JQuery Easy but this doesn't help either. My Joomla version is 3.0.4. I also use Akeeba backup and admin tools (reason for mentioning that is that those components have caused strange behaviour in the past, but initialy responsive banner slider was working ok).
Any suggestion is more than welcome!
Thanks.
12 years 6 months ago #3 by L
Hi i4all, Can you share your website URL so I can take a look?
12 years 6 months ago #4 by TemplatePlazza
The URL is www.ewva.nl
The banners that are using the responsive banner slider are on the left (under the agenda), under the blog articles and on the right between the clocks and the "KNRM banner". Thanks for checking.
12 years 6 months ago #5 by L
From what I see your website loads jquery libs for at least 3 times. Can you try to remove these calls :
www.ewva.nl/plugins/content/artsexylight...ightbox/js/jquery.js
www.ewva.nl/templates/ewva_005/jquery.js
Because joomla 3 loads jquery as default. No need top call it again from extension or template
12 years 6 months ago #6 by TemplatePlazza
