Problems With mod_latestnewsplusupdate
- Posted by phil (3) Offline
Hi Guys, not sure if you can help me.
I recently installed the lastestnewsplusupdate module, everything looks great. It shows the title of the module and a few lines about whats in it - perfect you may think. However when i click on the title of the article , it displays the full article within a white page (with extra text, as if its trying to load the template but can't). Now the other articles that are linked to menus show perfectly within the template, is there a way around this so as the newer articles that are not linked to a menu can display within the template?
Thanks all for your help if you need links etc please pm me, first post here so be gentle
12 years 7 months ago #1
by phil
Hmm strange, can you try to switch the template to the default one (beez) to check whether this is a template problem or something else?
12 years 7 months ago #2
Hi there,
Yes just tried that but to no avail - Perhaps I've changed a setting or something? But totally confused here
It's even happening when I use just the latest news module too I think...
Any other ideas?
12 years 7 months ago #3
by phil
Any other ideas?
Hi iris,Did you install any particular extension that is related to com_content?
12 years 7 months ago #4
It's even happening when I use just the latest news module too I think...Please Log in or Create an account to join the conversation.
Not that I'm aware off, have added all details for website etc with the first post just in case you want to login to the backend and have a look, thanks again!
12 years 7 months ago #5
by phil
Hi, I tried to enter your admin page but it loads very slow at my end, but I think I found the problem is.
It because your template gives a incorrect path for all template assets. See this screenshot ;
goo.gl/aYR2zH , all assest file paths include the article title in its path.
For example :while it should be :
12 years 7 months ago #6
For example :
http://www.allaspectsofhair.com/14-sample-data-articles/media/system/js/mootools-core.jshttp://www.allaspectsofhair.com/media/system/js/mootools-core.jsPlease Log in or Create an account to join the conversation.
