conflict with two extensions
- Posted by Axel (4) Offline
Ihave installed responsive banner slider but there is a connnflict with two estensions and i cant use a picture for the backgroung. I will like to translate read more in french.
Thanks for your help
12 years 6 months ago #1
by Axel
Hi, Itried to login to ypur website but it turns this error message :
12 years 6 months ago #2
Error
Unable to connect to LDAP server
hello,
Thanks for your reply. I give again my website name, username and password.
www.lilobayanzambe.com
Axel
12 years 6 months ago #3
by Axel
Axel
Ok, now I'm able to enter. It looks like you have installed several slide modules.
Can you try to disable or enable jquery loads from the responsive banner slider backend?
12 years 6 months ago #4
I have disable jquery and enable it but it dont work correctly.
12 years 6 months ago #5
by Axel
Hmm strange, it looks like the problem because this javascript file needed by the module is not loaded :
.. modules/mod_responsivebannerslider/assets/sequence/sequence.jquery-min.js
When you said it's conflicted with two extensions, can you tell me what extensions are those?
12 years 6 months ago #6
