Mini K2 link to item not opening in modal window
I'd like to open the K2 item/article in a lightbox/modal window.
In /modules/mod_minik2/tmpl/portfolio/default.php I changed <a href="<?php echo $item->link; ?>">
to <a class="modal" rel="{handler: 'iframe', size: {x: 800, y: 500}}" href="<?php echo $item->link; ?>">
but to no avail.
Problem is when you click in the miniK2 portfolio on the (K2) item image you get to the K2 item page and then it's difficult to get back to the miniK2 portfolio. Hence i want the K2 item/article to open in a lightbox.
Thank you so much for any help.
12 years 6 months ago #1 by Willem
Hi, Can you share your website URL so I can take a look?
12 years 6 months ago #2 by TemplatePlazza
Hey, thanks!
Here's the link : new.archidomus.be/index.php/projecten
12 years 6 months ago #3 by Willem
Hmm,
1. Have you added the code JHTML::_('behavior.modal'); in the php file?
2. Can you try to switch the template to the default joomla template (beez)? To check whether this is a template problem or something else
12 years 6 months ago #4 by TemplatePlazza
