Related Articles XTD washed out thumbnails
- Posted by Mattia (3) Offline
I've just purchased Related Articles XTD and I'm testing it on a local copy of my site (so I cannot provide you a link at the moment).
I see that when it creates thumbnails it "washes out" the image (the thumbnails has a very high luminance compared to the original image - see attachments). Is some filter applied to the thumbnails? How can I disable this?
Thank you.
12 years 6 months ago #1
by Mattia
Thank you.
Hi saldsi, sorry for delay in responding due to weekend offline.
Regrading your problem may I know your module parameter settings? I've tested at my end using your image and it worked fine. Here's the screenshot goo.gl/0Uaa0a
12 years 6 months ago #2
I tried to reinstall the module and to use default parameters, but I have the same problem.
Maybe it is related to different php version? On my local PC I'm using php 5.5.10...
12 years 6 months ago #3
by Mattia
Hi saldsi,
Ah yes it's probably because of PHP version under 5.5.11 that has a known bug with imageconvolution function (that is used by related xtd mod) : bugs.php.net/bug.php?id=66714
Can you try to update your php version to 5.5.11?
Or, maybe using the 5.4 version for now as 5.5 is not widely used yet.
12 years 6 months ago #4
