Carrousel Banner Width & Banner Height
- Posted by pepe (4) Offline
Do not change the size of the banner, the default is 468x60, but if I go up more or less I still keeping the same size image, even to modify it in the section of banners or carousel module
12 years 6 months ago #1
by pepe
Hi can you elaborate the problem more. I don't really understand it. Also, can you share your website URL so I can take a look?
12 years 6 months ago #2
Hello and thanks for replying
The web is www.connectingapps.es and the problem is I do not resize the banner to As I say, default carousel banner resized to 468 * 60 but if I change the size carousel does not show me as I ask, I do not make changes.
I hope I explained correctly.
thanks
12 years 6 months ago #3
by pepe
thanks
Hi nashevil, so you want to keep the original image size?
12 years 6 months ago #4
Because I want to use as a carousel module deals and want pictures look great, I have tried other pluguins other programmers and do not convince me, which is that I do better if I put a 468 * 60 pictures look very small, it is possible to modify it to my liking?
Thanks' a lot
12 years 6 months ago #5
by pepe
Thanks' a lot
Right now there are 800 * 514 images, even so shows me pictures of 500 * 321
12 years 6 months ago #6
by pepe
