responsive banner slider not working on joomla 3.2
Hi the Responsive slide banner that came with the dealsplazza template does not support Joomla 3.2 deals plazza template
I have upgraded the dealsplazza template to joomla 3.2 and the responsive banner slider wont show. what is the default position to select in the dealsplazza template as joomla 3.2 does not show cell-a1 and so on
see attachment
12 years 6 months ago #1 by matthew
Hi Matt,
I think we have told you several times before that indeed Deal Plazza does not support Joomla 3 (yet). It because of virtuemart, the component used on deal plazza still doesn't support Joomla 3 until now.
You have converted the deal plazza to joomla 3 by yourself so I think you already know the risk and we cannot provide you support for something that we didn't start. Sorry about that
12 years 6 months ago #2 by andy
I have re bought your deals template and installed it on my site and still responsive banner does not show I have con figured it identically as the original deals site but it wont show. what could be wrong?
11 years 6 months ago #3 by matthew
Hi Matthew, it' sprobably because of multiple jquery load issue by k2 and virtuemart. As described in the updated documentation file, please try to install this extension extensions.joomla.org/extension/jquery-easy to solve this problem
11 years 6 months ago #4 by TemplatePlazza
