MiniK2 Thumbnails not displaying
The thumbnails in my MiniK2 gallery are showing up a small white blank boxes. The title and intro text display but not the image. When I click the item it does correctly bring me to the item view showing the image correctly though. When I look at the source for the image when viewing the gallery it reads as follows...
data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///ywAAAAAAQABAAACAUwAOw==
I have no idea what this is or how it gets this but I believe this is the culprit. An ideas of why this is happening?
I apologize but I am currently developing locally for a client and do not have a URL that I can provide but would be happy to try and provide any additional info required.
12 years 5 months ago #1 by Matt
Hmm, it's a base 64 image format. Please see the original article to see whether a physical file embedded (.jpg,.gif or .png) or a base64 image format.
12 years 5 months ago #2 by TemplatePlazza
I'm not sure I understand what you are asking, the original image is a .jpg as I mentioned. I also tried it with a .png in case the .jpg was causing a problem but got the same result. I don't know where in my K2 Item to see if the embedded file is a .jpg or a base 64 image format.
12 years 5 months ago #3 by Matt
HI, Sorry for delay in responding due to weekend offline.
Btw, it's not easy to find a solution without seeing the website directly. From your information, the module returns a strange behaviour. Maybe you have a plugin or any else installed that processing k2 image and returns a base64 format one. I can't give you any sugestion without seeing it directly,
12 years 5 months ago #4 by TemplatePlazza
I came up with a solution, it isn't elegant but it was the only way I could make it work. Maybe this will help in understanding what is happening. When I add the module a second time to my page, the first module has the problem I discussed above, but the second one shows up fine. So I added the module twice, and use CSS to hide the first one and it works. Again, probably not the best solution but it works.
12 years 5 months ago #5 by Matt
Hi mgrenier,
Ah ok. Please come back again when your website has already online, so we can try to find solution for it
12 years 5 months ago #6 by TemplatePlazza
