Menu2Panel makes my site explode!
- Posted by Edward James (2) Offline
I'm trying to install Menu2Panel on my website and when I enable it, the site stops loading properly.
It strips out all my content but keep my ads on a white background.
Please help, your menu looks amazing!
12 years 5 months ago #1
by Edward James
Hi accessfashionmedia, I see so many js console error on that page (see goo.gl/mKUhJz ) . Can you see what js related modules are published on that page? Then try to unpublish it one by one to check what module is conflicted with menu2panel.
12 years 5 months ago #2
No, there are only ads and one other module.
Please look to see what your menu conflicts with. If not I would like a refund.
12 years 4 months ago #3
by Edward James
Hi, If so then it's probably because of your template. Please try to switch your template to the default one then disable that ads and the other module so we can see whether this is a template problem or something else
12 years 4 months ago #4
