Related Items Extended appears with the first scrolldown and it's hidden
Related Items Extended appears with the first scrolldown and it's hidden under the sidebar.
You can have a look here:
click-me.today/preschool/sizes/big-small...ig-small-worksheet-5
At your demo page it seems it works well.
demo.templateplazza.com/joomla/index.php...nded-module-slideout
What's the solution?
12 years 5 months ago #1 by Celine Miller
Hi cel mil, there are few possibilities, it's probably coming from your builtin template javascript or extensions you have installed on that page. The easiest way is to list what extensions are enabled on that page first, then try to disable it one by one to find what extension is conflicted with the related extended module. Once it found then we can continue to find solution.
12 years 5 months ago #2 by TemplatePlazza
Ok, thank you very much!
12 years 5 months ago #3 by Celine Miller
Ok, Please let me know if you still have the problem later
12 years 5 months ago #4 by TemplatePlazza
