Mini k2 problem
First just want to say this is a great module. I am having a couple issues with implementing this on my site.
1. On the homepage, I am only getting 2 columns to show up when displaying simple mode. Is there a way to have it show articles on 3 columns? On the other layouts, it seems to work.
2. I have tried to also make this into a module under individual articles, so it can show more content. However, I am having issues because it is adding this line of code to the top of the page:
.minik2 .k2item.block {width:200px;} .minik2 .k2item h2.title {font-size:24px;}
Also, when trying to use portfolio view etc, the module seems to break. I would like for the portfolio view to show 2 or 3 pictures per column like it does on the homepage, however when I use that view it lists each article and description in a single column under each other.
Any help would be greatly appreciated.
12 years 5 months ago #1 by Raj Vasa
Hi, it is 3 columns at my end, please see goo.gl/jmgtgt
I think it because of wrapper with of your main content area, that is not wide enough for 3 items in smaller monitor. Maybe you can try to reduce the minik2 item width in the module backend.
12 years 5 months ago #2 by TemplatePlazza
Strange, your website loads files that should be in the <head> section, in the <body> section. Can you try to switch your template to the default one to check whether this is a template related problem or something else?
12 years 5 months ago #3 by TemplatePlazza
Changed the template to default and the mini k2 is not showing up at all on the page.
12 years 5 months ago #4 by Raj Vasa
Also, what do you mean by Item width in the module backend? Is that the same thing as block width in simple?
12 years 5 months ago #5 by Raj Vasa
Are you sure you have published minik2 in the existing module position in the default template?
yes, that's it
12 years 5 months ago #6 by TemplatePlazza
