menu2panel not showing
- Posted by Catalin Rus (2) Offline
the menu2panel module I installed on my site is not working (not showing the button that opens the panel). I disabled all other modules that use jquery but still the same problem.
Any help is appreciated.
12 years 4 months ago #1
by Catalin Rus
Hi, it looks like your template loads multiple jQuery, have you checked that?
h**p://joomla3.xxxesign.eu/media/jui/js/jquery.min.js
h**p://joomla3.xxxesign.eu/templates/charlie/jquery.js
12 years 4 months ago #2
I installed jQuery Easy plugin and now the menu is shown in the module, but still not ok. It is not hiding and the menu button is not showing
Btw, what joomla version did you use on your website? Is it 3.3?
12 years 4 months ago #3
by Catalin Rus
Looks like there something with jquery easy plugin. I found the jquery is not loaded properly on your website. See goo.gl/WSePH6
Your website called ajax.googleapis.com/ajax/libs/jquery/1.11/jquery.min.js but it returned an error
12 years 4 months ago #4
