Mini K2 customization
I tried to add specific "K2 extra filed" to Mini K2 as explained in this tutorial:
getk2.org/documentation/tips-a-tricks/it...fic-extra-field-data
For some reason it doesn`t work. Is where some solution to display specific extra field in Mini K2 module (Simple template)?
Thank you in advance,
Gideon
13 years 11 months ago #1 by atanetfq
I believe you have standart K2 content module in place (mod_k2_content). If you take a closer look at it's mod_k2_content/tmpl/default.php, you will see this extrafields part below where you can paste it on .mod_minik2/tmpl/simple/default.php
<?php if($params->get('itemExtraFields') && count($item->extra_fields)): ?>
      <div class="moduleItemExtraFields">
	      <b><?php echo JText::_('K2_ADDITIONAL_INFO'); ?></b>
	      <ul>
	        <?php foreach ($item->extra_fields as $extraField): ?>
					<?php if($extraField->value): ?>
					<li class="type<?php echo ucfirst($extraField->type); ?> group<?php echo $extraField->group; ?>">
						<span class="moduleItemExtraFieldsLabel"><?php echo $extraField->name; ?></span>
						<span class="moduleItemExtraFieldsValue"><?php echo $extraField->value; ?></span>
						<div class="clr"></div>
					</li>
					<?php endif; ?>
	        <?php endforeach; ?>
	      </ul>
      </div>
<?php endif; ?>
Have a try...
13 years 11 months ago #2 by erwinschro
It doesnt help... I tried it before posting here. And I need to display specific extra field, not all of them
13 years 11 months ago #3 by atanetfq
I didn't read well before that you need only a specific extrafield.
For that then you need to count which one from those extrafields you've created in order. For example if it's an extrafield n-th then you should call it with
<?php
echo $item->extra_fields[n-1]->value;
13 years 11 months ago #4 by erwinschro
You mean, if I want to display extra field that has ID=1, so I should use this code ( n-1 = 1-1 = 0) :
<?php
echo $item->extra_fields[0]->value;
13 years 11 months ago #5 by atanetfq
my extrafields group name "book"
extrafield id 1 name "pages"
extrafield id 2 name "cover"
how i show in mini k2
13 years 9 months ago #6 by Mehmet
