Responsive Banner Slider Admin problem
On my test site running J! 3.3.1 using the Isis admin template viewed in Firefox 30.0, the Description, Menu Assignment, Module permissions, and Advanced tabs all load under the the Description tab. I found an extra openning <div> tag on line 8 of the en-GB.mod_responsivebannerslider.ini file that is causing a them to render the tabs incorrectly.
Also, when it was first installed, I could not save the any R.B.S. module. All of the Save options closed the item and made it locked, no changes saved. I messed around with purging site caches and eventually got something to work.
-Joel
12 years 4 months ago #1 by jdwires
Hi Joel,
Can you share your website URL so I can take a look?
12 years 4 months ago #2 by TemplatePlazza
I fixed the problem so there is not much to look at now. It was intended as more of an FYI. testsite.swcciowa.edu
12 years 4 months ago #3 by jdwires
Ah ok, thank you for the confirmation :)
12 years 4 months ago #4 by TemplatePlazza
I would like to know how this was fixed so I can fix mine too.
12 years 4 months ago #5 by Inter Naut
Hi internaut please open a new post with your website url so then I can check the problem
12 years 4 months ago #6 by TemplatePlazza
