Carousel Banner auto play doesn't work
- Posted by Hooman (10) Offline
Hello Guys,
I've tried different settings in the module but couldn't get the auto play working.
Any advice?
Hooman
12 years 4 months ago #1
by Hooman
Any advice?
Hooman
Hi hooman,
I've visited your website and I'm unable to find where is you install the module. Can you point me to the url so I can check it?
12 years 4 months ago #2
Sure, you can check it here: stkildamelbourne.com.au/test
It's at the bottom of the page, just below the texts.
12 years 4 months ago #3
by Hooman
Hi hooman, what joomla version do you have on your server?
can you try to disable the slider on the top section of your page then let me know what happens?
12 years 4 months ago #4
The Joomla version is 2.5.14 .
I've disabled the slider on the top but it didn't help.
Also just to make sure if there is anything wrong with my template. I've installed a fresh joomla here:http://stkildamelbourne.com.au/joomla/ but it didn't work on a fresh joomla installation either.
12 years 4 months ago #5
by Hooman
I tried to enter your admin page but it returns
12 years 4 months ago #6
Can you check it so I can enter to your test website so I can make some test?Username and password do not match or you do not have an account yet.
