Unnessecary 'p id=slidetag' caused by Related Items Extended?
I use another plugin to place modules within articles. Specifically, it is for placing ads in them. However, the Related Items Extended extension inserts an (in my opinion) unnecessary '<p id="slidetag">' in the bottom of the HTML module, which causes a somewhat ugly layout. See the source code between "START: Modules Anywhere" (line 156) and "END: Modules Anywhere" (line 180) in the reference link.
The '<p id="slidetag">' disappears if I disable the RIE extension. I don't use the slideout function of RIE, so is it possible to somehow remove the '<p id="slidetag">'?
/Magnus
12 years 4 months ago #1 by Magnus Ehinger
Hi, Yes that <p> tag is generated by related extended plugin as a slideout trigger when scrolling. If you con't use slide out type, you can remove it by disabling related extended plugin
12 years 4 months ago #2 by TemplatePlazza
Ah, I thought disabling the plugin "Content - Related Items Extended" would disable not only the slideout function, but all of the RIE modules. Thanks!
12 years 4 months ago #3 by Magnus Ehinger
No, that plugin is for slideout function only ;)
12 years 4 months ago #4 by TemplatePlazza
