Minik2 alignment
- Posted by Raj Vasa (9) Offline
I love your plugin. However, if you visit my site 360nightlife.com, you will see that the articles don't line up properly. I am viewing it on my macbook 13 inch. On iphone it works well because it is responsive and each article takes up the width. I am attaching a screen shot. Any suggestion on how to line it up right? Or is this maybe an issue where I need to make all images the same width / height and titles the same length?
i.imgur.com/Gta9AuS.png
12 years 3 months ago #1
by Raj Vasa
Hi I found that your website loads jquery twice,
www.dropbox.com/s/qunoq3h0urp7mrh/86jnn.jpg
Can you try to disable one?
12 years 3 months ago #4
Hi, I've visited your website and it looks like everything goes fine?
www.dropbox.com/s/6b6mynwzrwjwk2h/screen...360nightlife-com.png
12 years 3 months ago #6
