Connection Reset Related Articles Extended
Hi - when I enable the Related Extended module I get a connection reset error/bad gateway on the pages it is enabled on.
I'm not sure what is causing the error as the core related module is working fine. The issue is happening with the default template also.
Do you have any ideas on what to try and rectify the issue? I'd really like to get this module working.
12 years 3 months ago #1 by Liam
Your website quite slow from here, can you tell me whether this issue happened on all of pages or just specific page?
12 years 3 months ago #2 by TemplatePlazza
Specifically on all the article layout pages. It seemed to appear on the category page ok but not the layout page.
I have just enabled the module again for you to see.
3583d6d7.ngrok.com/barsec/Permanent-Barriers/U-Bars/
Sorry for the speed - it is on a local host
12 years 3 months ago #3 by Liam
Hmm the website speed is really slow. Can you tell me what module or plugin are installed/enabled on the page where the issue exist?
12 years 3 months ago #4 by TemplatePlazza
