Adding space between images
- Posted by Raj Vasa (9) Offline
First, thanks for your help with the last problem. I was able to find the conflicting Jquery load and it works fine now. The question I have now is a styling question.
Basically, I wanted to increase the title sizes to make it more prominent on the website. When doing this, the intro text gets mushed up and disappears under the image on the next row. I been searching your CSS to find a solution to this and was wondering if you might have a hint or tip on what to do change. I was thinking I would need to add a bottom margin to the block img or thumbs-wrapper?
Any help would be greatly appreciated.
12 years 3 months ago #1
by Raj Vasa
p.s. I noticed that for individual images I can edit the TOP style and it would achieve what I want, but I believe those positions are controlled somewhere else. ie.<div class="k2item block masonry-brick" style="opacity: 1; position: absolute; left: 222px; top: 320px;">
12 years 3 months ago #2
by Raj Vasa
Hi Can you make a change to your website so I can see the problem?
12 years 3 months ago #3
It's controlled by masonry jsI believe those positions are controlled somewhere else
