Carousel Banner settings
PHP version: 5.3.28
WebServer: Apache
PHP interface: cgi-fcgi
Joomla version: Joomla! 3.3.1
This is a wonderful joomla extension but I am getting some issues.
It is working but not the way I like.
I need to set the module to publish banners two ways:
1-only one line with scrolling banners one each time.
2- two lines scowling two banners each time, one below the other.
What happens after I get the first time the 2 line banners I can revert back to 1 line banner but the module height stays the same for the two banner layout.
On the 2 lines sometimes I get only one banner and others two banners one below the other so when I get one banner there is a large unused space bellow that banner.
Other thing I would like to control is the time to start scrolling and between each sequence.
Is it possible to do it ?
Is there any way to disable the jQuery library on this module ?
Thanks in advance
12 years 3 months ago #1 by macweb
To create it you can make two module and place it in the same module position right?
The module should not load jQuery, why you think it loads jquery?
12 years 3 months ago #2 by TemplatePlazza
When I set "Visible Items" to 1 to accomplish this I get a double module height.
How can I set it to show only 1 banner each time with the normal module height ?
I just make this question because I saw that the module was showing two lines of banners so I thought it was a function.
12 years 3 months ago #3 by macweb
Hi Macweb, Sorry for delay in responding,
Are you speaking about flexisel type of animation or the default one?
Also, Can you share your website URL so I can take a look?
12 years 3 months ago #4 by TemplatePlazza
Sorry about the delay.
The website is still in my localhost no dns yet.
I am using flexible.
12 years 3 months ago #5 by macweb
Hmm, it's not easy to play with that without seeing it directly. Please let me know again when you already have your website online
12 years 3 months ago #6 by TemplatePlazza
