Just bought Menu2Panel and does not work
Just bought Menu2Panel and does not work.
Installed in a Joomla site with gavick template and does not work at all.
The only thing it does is display the menu items vertcally, no button, no styling, no panel, no crap
Please need fix asap or money back
Tks
12 years 3 months ago #1 by Elliot
it doesnt even work in default joomla template
12 years 3 months ago #2 by Elliot
Hi, I can't opened your website because it's password protected. Can you remove it please so I can check it?
12 years 3 months ago #3 by TemplatePlazza
Your menu is displayed at the very bottom
12 years 3 months ago #4 by Elliot
It because your website loads too many jquery libs, and one of them is loaded after menu2panel js that will produce the error.
See this www.dropbox.com/s/90c7gb4330v3729/8eb1a.jpg
Please make sure only one jQuery lib is called by your website/template, and for menu2panel, you can disable jquery lib from the menu2panel backend
12 years 3 months ago #5 by TemplatePlazza
Well i installed jquery easy and now is loading only one.
Tried with the default mode and also allowing the script from your extension to load.
None of them works.
Tried with Beez2 joomla template with no modules, so only default scripts are loaded and still does not work.
Plus there are plenty extensions there and they all work fine.
Yours is the only one that does not work.
So please, Fix it or give my money back.
I don´t have the time to find the bugs in your extension.
Tks
12 years 3 months ago #6 by Elliot
