JQuery peel function not working/Flash working
Hi, I think this is a great extension but I am having a problem!
Flash functionality works for peel and mirror but when I set it to JQuery the animation doesn't work anymore?
My URL is www.southernobedienceclub.com can an admin have a look and advise when they have time?
12 years 3 months ago #1 by DBB
Hi Can you change that to jquery mode so I can see the problem?
12 years 3 months ago #2 by TemplatePlazza
I have switched it to jquery mode now.
12 years 3 months ago #3 by DBB
Hi, I see there's a console error with the sticky nav,
www.dropbox.com/s/pgpr4odwra8nhq3/mljmd.jpg
Can you try to disable it then let me know the result?
12 years 3 months ago #4 by TemplatePlazza
I dont suppose you have an idea of how to fix the console error? I'm a bit of a n00b
12 years 3 months ago #5 by DBB
Can you try to disable this module www.dropbox.com/s/1orsqt6m5kz0ybw/Home.jpg to see whether this is javascript confliction issue with that module or something else
12 years 3 months ago #6 by TemplatePlazza
