Carousel Banner - Multiple Banner on Same Page
- Posted by Hitesh (4) Offline
Hi There,
First of all, great extension. Had few glitched but then worked like a charm.
I have multiple Banners on same page. and both has different dimensions. The problem is that second banner is picking up width of first banner. I am not sure how to fix that. I tried different class prefix but had no luck
Please advice me how to fix that.
12 years 2 months ago #1
by Hitesh
Hi Admin,
Here is website link: nit.com.au/
As you can see there are two banners on home page. .One on top and one on right side.
12 years 2 months ago #3
by Hitesh
Hmm, the width is calculated automatically by the javascript and it's indeed not tested for multiple use on the same page.
Can you try to add this code to your css file :
12 years 2 months ago #4
#mycarousel262 .jcarousel-item {
width:245px!important;
Thanks Admin,
It removed space between banners but banners didnt scrolled correctly. Only 2 banner scrolled and third was half.. and they started again from first..
12 years 2 months ago #5
by Hitesh
Hi, How about this one :
12 years 2 months ago #6
.jcarousel-skin-tango .jcarousel-clip-horizontal #mycarousel262 {
width: 245px!important;
