Pay with Social opening a blank window
I purchased the Pay with Social plugin for my joomla 2.5 site.
I've added the PWS code on one article to test it here:
www.careersportal.co.za/learnerships/tra...p-at-homechoice.html
But it doesn't seem to work. It showed 1 tweet before I tweeted it and the button is unlocked but when I click it, it opens a new blank window.
I've added this link code in the article:
{paysoc}3888|||tweet|http://www.homechoiceholdings.co.za/careers/vacancies.asp|en_GB{/paysoc}
I'm testing this with twitter 1st. If it works then I'll attempt to get it working with facebook.
Please can you have a look at the links above and advise as to what I should do to get this to work.
12 years 2 months ago #1 by Nathan
Hi, can you try to disable this share buttons and let me know the result ?
www.dropbox.com/s/8jevwz1eeokg0o7/c90lx.jpg?dl=0
12 years 2 months ago #2 by TemplatePlazza
Thanks. I tried that and it doesn't seem to have made a difference.
We're using cloudflare. Is it possible that the caching is causing this issue?
I will leave the other social sharing plugin disabled for now while we troubleshoot the issue.
12 years 2 months ago #3 by Nathan
Hi, I don't think it because of cloudflare. The error console shows that there's a confliction with all.js of facebook.
www.dropbox.com/s/5lutdyabfgdr1wv/sohsp.jpg?dl=0
Can you try to disable the facebook comment in the bottom side?
12 years 2 months ago #4 by TemplatePlazza
I've removed the facebook comments box as well and it still doesn't work.
What else can I try?
12 years 2 months ago #5 by Nathan
Hmm can you try to disable this jquery from your template ; www.careersportal.co.za/templates/careerstemplate/js/jquery.js
because when I look at the html source of your website, there are two jquery libs are loaded. one in the top of page and one in the bottom.
www.dropbox.com/s/gqnkxnuwzmpq8yf/w7fsx.jpg?dl=0
12 years 2 months ago #6 by TemplatePlazza
