Mini front page disables a widget.
Hy.
I used your awesome module mini front page on our previous version of our website and it worked fine. Now I've updated the design a bit and added widgetkit. The widget that you can see at the top of our website (maribor1.skavt.net) is a slideshow of pictures. But every time I enable the mini frontpage module the slideshow stops working. Now since no other module causes this problem (no matter where I place it) causes this problem I presume this is a glitch that is caused by mini frontpage. We are using joomla 2.5 (and we did install the proper version of mini front page for our version of joomla). Also I tried this on multiple browsers and the problem remained.
Also the thumbnails don't display (but that's another problem all together).
12 years 1 month ago #1 by Viktor
Hi, can you try to disable jQuery load in the minifrontpage parameters?
www.dropbox.com/s/jk6vnhzrnhhx4cp/515xm.jpg?dl=0
12 years 1 month ago #2 by TemplatePlazza
That did the trick :D Now I just have to figure out why the images aren't loading :p
12 years 1 month ago #3 by Viktor
ok ;)
12 years 1 month ago #4 by TemplatePlazza
