Editing layout for MiniTicker
- Posted by Lee Collings (4) Offline
How can I edit the markup for the 'Ticker Title' value, as specified in the Admin area?
I've created an override for the module, but this doesn't go that far back. It only allows me to edit the list of items that are displayed.
The title is surrounded by <span> tags, which allows styling, but I want to make this title linkable to another page on my site.
12 years 1 month ago #1
by Lee Collings
Hi Can you let me know the URL of your site so I can take a look?
12 years 1 month ago #2
It is generated by generated by js actually. How about to add something like this in the Title Text at MiniTicker backend :
<a href="http://wyourwebiste"" target="_blank">Headlines
12 years 1 month ago #3
If it still doesn't work, try to addd this jquery anywhere on your template
12 years 1 month ago #4
jQuery('.ticker-title').click(function(){
window.open('your-url.com');
return false;
});Please Log in or Create an account to join the conversation.
None of these options work.
The <a> tag in the backend won't work because upon saving, it simply gets stripped out, and reverts to the text inside the <a> tag.
And the jquery doesn't seem to render anything, using both jQuery and $ at the start.
Are you able to re-work it so that this title area appears in the layout php files, so it can be overridden?
12 years 1 month ago #5
by Lee Collings
open file /module/mod_miniticker/miniticker.xml, arround lines 83 find this line :The <a> tag in the backend won't work because upon saving, it simply gets stripped out, and reverts to the text inside the <a> tag.
<field name="tickerTitleText" type="text" default="Headlines" label="MOD_MINITICKER_TICKERTITLE_LABEL" description="MOD_MINITICKER_TICKERTITLE_DESC" />change with
<field name="tickerTitleText" type="text" default="Headlines" label="MOD_MINITICKER_TICKERTITLE_LABEL" description="MOD_MINITICKER_TICKERTITLE_DESC" filter="war" />Please Log in or Create an account to join the conversation.
