Related Items Extended not showing
Related Items isn't showing. Ive enabled Plugin, enabled the module, set it to show on certain pages and selected a position but still not working?
Also whilst the plugin is activated it stops my home page news slider from working - could this be to do with the problem?
Plug-in currently deactivated.
11 years 11 months ago #1 by Rick
Hi, I'm unable to locate the module. Can you point me a page where you enable it?
It's probably a multple jquery load issue. Please try to disable the jQuery load from the plugin backend.
www.dropbox.com/s/usods1stlyuydf6/yoo8f.jpg.jpg?dl=0
11 years 11 months ago #2 by TemplatePlazza
Thanks for the reply,
You should be able to see the module active here: rickinghamphotography.co.uk/site/index.p...-eurocopter-puma-hc2
Its enabled as 'Related Items Extended' here rickinghamphotography.co.uk/site/adminis...p?option=com_modules
Plug-in is enabled with 'no' selected on jquery
11 years 11 months ago #3 by Rick
Hi, I have entered your administrator page and I found that the article "Eurocopter Puma H2" doesn't have any meta keyword that is needed by related item extended module to find any other related article.
Please try to enter one or more meta keyword for that article and other article that you think is related.
11 years 11 months ago #4 by TemplatePlazza
I have applied meta keywords to that article and another that is related...still nothing
11 years 11 months ago #5 by Rick
Hi, Is the user-3 position (used by related items module) really available? I tried to publish a custom module under user-3 position and it doesn't show up in your website front page
11 years 11 months ago #6 by TemplatePlazza
