Can't get peel banner to work
- Posted by Nadav Levy (3) Offline
I tried testing page peel banner on my website: edoula.me/en/my-pregnancy-story-en/share-your-story.html
I can see the small "peel me" image, but when I hover it and it open there's a problem.
When using JQuery I see white area, when using flash I see my website.
Please advise what else should I try.
Thanks,
Nadav
12 years 4 weeks ago #1
by Nadav Levy
Thanks,
Nadav
Hi, can you try to switch your template to a default one (protostar) to check whether this is a template problem or something else?
12 years 4 weeks ago #2
Tried and still see white space once it's peeled.
May I have something wrong with the module settings? Please see attached images with my settings and the page with peel banner closed and opened.
12 years 4 weeks ago #3
by Nadav Levy
strange, can you tell me what extensions you have installed on that page?
12 years 4 weeks ago #4
To make things easier I'd setup a new temp page which had nothing on it and had the same problem.
It's working now. The problem was with the banner settings on Joomla banners component. I guess I must setup client...
12 years 4 weeks ago #5
by Nadav Levy
