Responsive Banner module questions
Sorry... Two more questions about Responsive Banner. I am using the "Sequence" type.
1 - Is it possible to set the speed of the transitions? Not the time the banner is showing, the speed of the effect where the slide and type appear.
2 - Is it possible to set the font of the type?
Thank you for your help.
12 years 2 weeks ago #1 by bw92116
Yes, it is possible but you have to edit a quite alot css code manually, to change the timing
yes, you can override it by using css
12 years 2 weeks ago #2 by TemplatePlazza
ok
12 years 2 weeks ago #3 by bw92116
