Issues with Related Items Extended on Thumpnails and Category Filter function
- Posted by Sunny (2) Offline
Hi there,
I have 2 Issues
1. I install the module but the image thumbnails doesn't appear on my site
Check this link diastixo.gr/kritikes/texnes/3089-sinomilia-me-tin-petra
2. You say at the version Version 1.4 - 17/07/2014 + Added Category Filter function but in module i cant find this function. only Meta & tags.
12 years 1 day ago #1
by Sunny
I have 2 Issues
www.dropbox.com/s/sb6xsioe3zgadec/juzk5.jpg.jpg?dl=0
Can you check it?
12 years 1 day ago #2
It probably because your image paths contains spaces. Can you remove space your "Book Cover" folder name? Maybe something like book-cover1. I install the module but the image thumbnails doesn't appear on my site
It's located under the "Select Category" field2. You say at the version Version 1.4 - 17/07/2014 + Added Category Filter function but in module i cant find this function. only Meta & tags.
Can you check it?
Hi again,
its ok with the "Select Category" field.
For the other issue, i cant change the folder name, from "Book Cover" to book-cover becouse 6000 articles they lost the image. Any other solution plz? something on code to change?
12 years 1 day ago #3
by Sunny
Hi Sunnygr,
Hmm just wondering, how did you add the image to the article? Joomla insertimage dialog shouldn't allow you to browse a folder with folder with a space in its name, because it sometimes will create path related issue.
If you'd like to use the 'original image' solution, please copy the attached folder mod_relateditems_xtd below to folder
: templates/your_template_name/html/ so it can override the module output
12 years 19 hours ago #4
The possible workarround I think is to use the original images for the thumbnails, or to disable the thumbnail (you can do this from the module backend).Any other solution plz? something on code to change?
