Related Items Extended ordering by article order
I'm interested in buying Related Items Extended. Does it support showing links by article order in a category (in the first article it shows links to the 2nd, 3rd and 4th article and so on)
11 years 11 months ago #1 by Andrew
Hi, Yes it does. The available options are : Recently created, article ordering, Random and Hits,
See this : www.dropbox.com/s/239suz8dv9yetfd/hp344.jpg?dl=0
11 years 11 months ago #2 by TemplatePlazza
in "Article Ordering" mode it only shows links to the last articles on all pages.
11 years 11 months ago #3 by Andrew
Hi, I have retested it, and found it works properly. Please see this video www.dropbox.com/s/rcrfo9ruzeqxr35/rieeor.mp4?dl=0
11 years 11 months ago #4 by TemplatePlazza
thanks for explanation. maybe it conflicts with other extension. and one more question, if there are more than 4 articles in a category will it display different links on a different article pages?
11 years 11 months ago #5 by Andrew
umm it should not be conflict with other extension because it's only php without javascript, unless you use the slideout style.
I'm not really sure what did you mean but you can test it yourself. Basically it will display related articles based on meta or tag relation (depends on what option you choose). If two articles have identical tags or meta keywods it will likely be displaying the same related items
11 years 11 months ago #6 by TemplatePlazza
