Text Color Too Light
I love the mini K2 module. But you've made the grey text so light (like this text box here) that it's nearly invisible to elderly folks - my main website audience. Is there a way to change the color?
11 years 11 months ago #1 by Lisa Jorgensen
Hi, yes, it should be easy by adding a small piece of css code to your template css. Can you let me know the URL of your site so I can take a look?
11 years 11 months ago #2 by TemplatePlazza
The URL is LakeChapalaReporter.com.
11 years 11 months ago #3 by Lisa Jorgensen
Hi, Try to add this code anywhere on your css file :
.minik2-simple-intro {
color:#000!important;}
11 years 11 months ago #4 by TemplatePlazza
That looks much better. Thanks very much. You should have that color as the default :)
11 years 11 months ago #5 by Lisa Jorgensen
no problem glad it helps ;)
11 years 11 months ago #6 by TemplatePlazza
