Page peel jquery
- Posted by shaun (2) Offline
When i set page peel to jquery it is not showing in front end. I dont want to use flash. Can you please help me ?
11 years 11 months ago #1
by shaun
It's probably a multiple jquery issue. Try to use this plugin extensions.joomla.org/extensions/core-en...jquery-scripts/18327
11 years 11 months ago #2
OK did that but still not working ! The is no animation on the module
11 years 11 months ago #3
by shaun
It's still jquery problem. Have alook on this www.dropbox.com/s/hsywnftckw9cvkg/qunjq.jpg?dl=0
The jquery on your website is loaded in the <body> section not in the <head> section. Please try to switch your template to the default one to see whether this is a template problem or something else
11 years 11 months ago #4
