Related Items Extended questions
I need to change some settings in the module:
- How to translate “Related Items” into italian?
- How to set it to appear a bit earlier than the real bottom of the page?
- How to override the font setting (colore and size) to prevent future update restoring? To set a different font color I need to change it into module css file, the Gantry ovveride doesn't work.
11 years 10 months ago #1 by theant
You can create your own translation by duplicating and modifying this file [root]/language/en-GB/en-GB.mod_relateditems_xtd.ini to [root]/language/it-IT/it-IT.mod_relateditems_xtd.ini
You can try to add this code to your css file
#slidetag {
margin-top:-300px!important;}
You can add the override to your gantry css files. If it doesn't work, try to add
!important
at the end of your css properties
11 years 10 months ago #2 by TemplatePlazza
Thanks a lot.
Only the last one isn't ok because breaks the category blog layout.
11 years 10 months ago #3 by theant
Can you tell me what you're trying to change and how did you do that? Alsp, can you let me know the URL of your site so I can take a look?
11 years 10 months ago #4 by TemplatePlazza
www.vorrei.org/culture/10430-rossella-mo...rale-in-brianza.html
adding
#slidetag {
it breaks the category blog layout in pages like this:
www.vorrei.org/culture.html
11 years 10 months ago #5 by theant
Hmm, i didn't see any (considered as) broken layout on that page. Can you tell me what it's supposed to be ?
11 years 10 months ago #6 by TemplatePlazza
