Responsive Banner Slider problem
After upgrading NoNumber Advanced Module Manager my Responsive Banner Slider stopped to work. Before uopgrade-ing it works normally. If I disable NoNumber Advanced Module Manager, my RBS (Responsive Banner Slider) works normally.
I need both of them, NoNumber Advanced Module Manager and RBS.
I buy most recent RBS, and I think that is some coding "overlapping" issue, maybe it will be resolved in best way in contact with nonumber developer? He knows what changes are done recently, and you will know what will break your RBS Nivo slider to work? I have Joomla 3.3.6, latest version of RBS and latest version of Nonumber components....
If I should supply more info, please let me know....
Best regards, Jovan
11 years 10 months ago #1 by Jovan Sandic
Hi Jovan,
Can you let me know the URL of your site so I can take a look?
11 years 10 months ago #2 by TemplatePlazza
URL is srbcounciluae.com/
Web site is live, so I already turned off NoNumber Advanced Module Manager in order to RBS Nivo slider work.
We should be at same time online, then I will turn on NoNumber Advanced Module Manager so you can see whats wrong.
11 years 10 months ago #3 by Jovan Sandic
Hmm, strange. I have tried to install both in of RBS and AMM but I'm unable to replicate the problem. It works good at my end.
Can you tell me step by step what did you do so I can replicate the problem?
11 years 10 months ago #4 by TemplatePlazza
