Module in Modal
- Posted by Martand Biniwale (6) Offline
Hello ,
I just purchased the extension yesterday .
I am not able to run 2 Types of ''Module in Modal'' at the same time .
If i try to run at the same time then the other module will popup with it .
Is there any way to solve it ?
Another issue : The content below (Slider /Tabs) is overlapping ''Module in Modal'' .
B-Rgds
11 years 9 months ago #1
by Martand Biniwale
B-Rgds
Hi Martand,
Yes, it is intended to load only one modal in one page. Can you tell me what you're trying to achieve?
11 years 9 months ago #2
Can you let me know the URL of your site so I can take a look?Another issue : The content below (Slider /Tabs) is overlapping ''Module in Modal'' .
Hello ,
I using JBounce & Module in Modal .
1) If you visit www.tt-arena.com/how-does-it-work and try to close it Jobounce displays same issue as Module in Modal.
The content below is overlapped .This sometime happens on the Frontpage also for Module in Modal .
So i am not able to keep the size of Module in Modal big .
Ps: currently I am using Module in modal on Bottom Right to show a translation option .
I was trying to use Translation module and Login module option at the same time on all pages.
11 years 9 months ago #3
by Martand Biniwale
Hi martan, sorry for delay in responding. Can you try to use other template to check whether this is a template problem or a css conflict with other extension?
11 years 9 months ago #4
Hi ,
Just need to check with another template . Will get back to you .
B-Rgds
11 years 9 months ago #5
by Martand Biniwale
B-Rgds
Hello ,
Yes it gives the same problem for other templates .
It goes under the Content .
B-rgds
11 years 9 months ago #6
by Martand Biniwale
B-rgds
