Minifrontpage links not working since update
- Posted by Hahn Claire (4) Offline
I'm stuck, I've done the latest update of Joomla 2.5.28 and since my links on minifrontpage won't work anymore. I think the pb is the same as www.templateplazza.com/forum/latestnews-...aren-t-working-right
But I just don't know what to do.
I hope you will be able to help me.
Thank you !
11 years 7 months ago #1
by Hahn Claire
Thank you !
- Posted by dlw1433 (1) Offline
I'm having the same problem. I've updated to Joomla 3.3.6 and updated to Mini Front Page 2.2.3. I'm getting error codes when I try to publish:
Warning: Division by zero in /home3/smerry/public_html/modules/mod_minifrontpage/helper.php on line 346
Warning: Division by zero in /home3/smerry/public_html/modules/mod_minifrontpage/helper.php on line 350
Is this version compatible with 3.3.6?
Can you let me know what I should check to make this go away?
Thanks... D
11 years 7 months ago #2
by dlw1433
Thanks... D
Hi guys,
Can you guys let me know your urls so I can have a look?
www.dropbox.com/s/5ruxo6mhn761amm/mfpp.mp4?dl=0
Btw,are you guys sure have installed the proper mini frontpage version? There are two version of mini frontpage. One for joomla 2.5 one for joomla 3.x If you upgraded your joomla from 2.5x to joomla 3.x you need to reinstall the module too, use Joomla 3.x version.
11 years 7 months ago #3
Yes, please see this video :Is this version compatible with 3.3.6?
Thank you for your reply, I'm still on Joomla 2.5.58 so yeah it's the right version.
If you go on the "news" part (minifrontpage), the links just act weird and don't work, just like this other message www.templateplazza.com/forum/latestnews-...aren-t-working-right
Thanks again
Please help me
11 years 7 months ago #4
by Hahn Claire
Thanks again
Please help me
Do you use different template for your 'home' page and other pages?
11 years 7 months ago #5
I think it's a known joomla item id issue. You can solve it by creating a new hidden "category" menu item for the news article category\
11 years 7 months ago #6
