Deal Plaza template
- Posted by Per Claussen (6) Offline
Popup login don't behave correctly on iPad. The popup shows up, but disappears when touching the user-id field.
I'm on Safari under iOS 8
11 years 9 months ago #1
by Per Claussen
It has been fixed in 1.21 version. Please redownload the package. If you're willing to update it manually, please open the file templates/deal_plazza/css/template.css
arround lines 109 find this code
change with
11 years 9 months ago #2
.stick .cell-3b-inner {
display: none;
}change with
padding: 0;
.stick .cell-3b-inner .poplogin,
.stick .cell-3b-inner .search-box
display: none!important;
- Posted by jacoba (3) Offline
Could you please tell me where I can find the CSS tweak for the header menu. I would like to change the colours. I have been looking and changing but the blue colour stays on top ;(((
11 years 6 months ago #3
by jacoba
Hi jacoba, it's templates/deal_plazza//css/menu.css. Have you checked it?
11 years 6 months ago #4
YES..I've changed the lot in menu.css but the BLUE color on top is a mystery. Could you tell me where I can find it.
I have another small issue about the width/fluid of the template. I would like a template wrapper of say 960 px. Any chance you can help me with it?
You've made one of the best responsive templates in the market
Keep up the good work!
Thank you
kind regards,
Coby
the Netherlands
11 years 6 months ago #5
by jacoba
Thank you
kind regards,
Coby
the Netherlands
Hi coby, Umm sorry I don't really get that. Did you mean 'the blue' color is the 'active' state of the menu items?' www.dropbox.com/s/tco3byyoil3dgvu/tjqab.jpg?dl=0
11 years 6 months ago #6
