Fonticons Plus
- Posted by Andreas (7) Offline
I've purchased fonticons plus just some minutes ago and installed it for TinyMCE like described in the documentation.
I was able to insert icons, but had the following problem: All formating concerning new paragraphs (done with breaks) of the included text in the TinyMCE editor disappeared. I'm not able to set new paragraphs with breaks, also the positioning of the icon via breaks is not possible. I've deactivated the plugin, erased the editor.css, but only when I'm deleting the "i[class|style]", the problem is disappearing.
Help is really appreciated.
Unfortunately, the page isn't online at the moment.
Thx.
Many regards
Andreas
11 years 7 months ago #1
by Andreas
Thx.
Many regards
Andreas
Hmm strange,
Can you let me know what joomla version do you use and also, if i[class|style] is deleted, are you able to add icons?
11 years 7 months ago #2
I'm using Joomla 3.3.6 for this website. Unfortunately when I'm deleting "i[class|style]" it's not possible to add further icons. Indeed I'm able to open the icon window with the editor button of font icons, but it's not possible to insert an icon. Page breaks in the editor window (Tiny MCE) are shown, but when I'm saving the content of the editor window, all page breaks are deleted. Have no idea why.
11 years 7 months ago #3
by Andreas
Hi ghul can you tell me step by step to reproduce the problem? I have tried it on my localhost and everything looks ok. please have a look on this video www.dropbox.com/s/2bp66s1m3i1xg1i/fonplus.mp4?dl=0
11 years 7 months ago #4
I've tried again to activate and use Fonticons Plus like described, but I was not able to solve the problem.
Just one example for you with the attached zip-archive: I activated all necessary plugin, but did not insert the following at the TinyMCE: "i[class|style]". Up to this point every works fine, when I'm adding the code, all breaks are disappearing and the formatting is destroyed. Perhaps could there be a problem in connection with other plugins or modules?
I've added also screenshots of the code before and after adding the code and the html-code of the backend page, perhaps it will help to solve this issue.
THX.
br
Andreas
11 years 7 months ago #5
by Andreas
THX.
br
Andreas
Really strange. Can you try to disable other external content plugins you have, to check this is something related tp other plugins or something else.
11 years 7 months ago #6
