MEnu 2 Panel
Hi, First up, great product.
I do, however, have one issue. When loading a page, and in particular one with google mapping or via a slow connection I can see the menu load before the rest of the has js/css takes over and hides the contents of the menu. Please see attached.
Do you have any ideas how I can get round it so it loads without showing the content?
Thanks in advance.
Tim
11 years 8 months ago #1 by Tim Vaughan
Hi timp, thanks.
Can you check whether the same issue appear on the demo site ? demo.templateplazza.com/joomla/index.php/menu2panel
Can you try to publish the module in the bottom position of your website (footer)?
11 years 8 months ago #2 by TemplatePlazza
Thanks for your response.
I have placed it in the footer as requested. It looks like its not happening as it loads in later. It might be not anything to do with your plugin but I don't suppose you could help to see if there is a resolution to this?
Thank you.
Tim
11 years 8 months ago #3 by Tim Vaughan
Hi Tim, Can you check whether the same issue appear on the demo site ? demo.templateplazza.com/joomla/index.php/menu2panel
11 years 8 months ago #4 by TemplatePlazza
Sorry, missed that bit off. No, it doesn't..
Tim
11 years 8 months ago #5 by Tim Vaughan
Sorry for delay in responding
then it's probably because of your template or other extensions styles. Can try to swith the tempalate to default one and check whether the problem persist or not?
Also can you let me know the URL of your site so I can take a look?
11 years 8 months ago #6 by TemplatePlazza
